Reference Qualifier not working for 2 variables
Emp 53
i written below script but it's not working as expected in reference qualifier if i call 2 variables in ref condition.
Provider : AWS
Provider_1 : AWS, Azure,VMWare
working condition: javascript: new provider().Info(current.variables.provider);
Condition not worked:
javascript: new provider().Info(current.variables.provider,current.variables.provider_1);
Info: function(provider) {
var list = [];
var gr = new GlideRecord("u_account");
gr.addQuery("u_provider", provider);
while (gr.next()) {
list.push(gr.sys_id.toString());
return 'sys_idIN' + list.join(',');
BharathChintala
@Emp 53  If that variable is referred to u_account table then no need of script include
write this reference qualifier.
javascript:  ‘u_provider=‘+current.variables.provider
if above didn’t work means
if it is record producer write producer. Instead of current
cat item write item. Instead of current
If my inputs have helped with your question, please mark my answer as accepted solution, and give a thumb up.
Bharath Chintala
Hi @Johns Marokky
I have two questions here. What is the field type of provider_1 whether it's a list? -- it's multiple choice Variable
Also, In Provider_1, I can see there are three values. So basically I am assuming that you need to show the values of account of all three providers. Am I right ? -- yes based on provider i need to display account but a time it's supporting only 1 provider
Hi @Emp 53 ,
Please change your script include to the below code. I think it might work.
Info: function(provider,provider_1) {
var list = [];
gr.addQuery("u_provider", provider).addOrCondition("u_provider",'IN",provider_1);
while (gr.next()) {
Modify the script include and see if it works.
If not we might need to drill down the type of fields available in the "u_account" table and the ones you are using as the variables.
Mark Helpful and accept the solution if it helps in Solving your query.
Johns
BharathChintala
Bharath Chintala
