Reference Qualifier not working
Joe Taylor
Giga Guru
Why isn't this reference qualifier not working?
javascript:'sys_id!=NULL^ORDERBYu_order'
2 ACCEPTED SOLUTIONS
Thanks to everyone for their suggestions.
I finally got this working.
I changed it back to a "Simple" Reference Qualier.
Then I added "ref_ac_order_by=u_order" in the Variable attribute field.
Hi @Joe Taylor
what you accepted as solution is exactly what I replied above:
https://www.servicenow.com/community/itsm-forum/reference-qualifier-not-working/m-p/3352395/highligh...
and
https://www.servicenow.com/community/itsm-forum/reference-qualifier-not-working/m-p/3352375/highligh...
I'm really glad that it solved your issue, but now it'd be fair to accept my replies as solution, not your own... you basically did what I've been saying the whole time. :))
Thank you for considering to accept my solution. If not, then I'm happy you solved your issue but again it's not fair and actually against the Community's code of conduct.
11 REPLIES 11
Nikhil Bajaj9
Tera Sage
Hi @Joe Taylor ,
What is happening, can you share some screenshot so that we can understand what si happening?
Nikhil Bajaj
Bhuvan
Giga Patron
@Joe Taylor
You can set up a simple reference qualifier for your requirement.
https://www.servicenow.com/community/developer-articles/reference-qualifiers-in-servicenow/ta-p/2765...
I think you just copied syntax from a post and is in-correct, use below if you need to try using advanced reference qualifier,
https://www.servicenow.com/community/developer-forum/reference-qualifier-quot-orderby-quot-and-javas...
Bhuvan
