Reference variable for sys_user_grmember only shows sys_id; need to show Group names (and only unique names at that)
apj_pga
The crux of the issue is (while testing in a non-prod instance):
  • Added a reference varable to the sys_user table called 'Default Group' (u_default_group), which refers back to the Group Member list (sys_user_grmember).
  • In the User form, when I click the magnifying glass, the popup list that opens up only shows sys_id
Things I've done in trying to make the popup list show actual group names:
  • In Dictionary Entries > Table = sys_user_grmember, found 'Group' and set 'Display' to true
  • In Dictionary Entries > Table = sys_user_group, found 'Name' and set 'Display' true
Those changes did have one effect: When I start typing a value into the 'Default Group' variable box now, the auto-complete/suggested, human-legible group names actually do show up (see below 1), but it's still showing only the sys_id if I click the magnifying glass icon (see below 2).
"below 1"
"below 2"
Additionally, when the auto-complete options show up (as I start typing a value), they show multiple values for each group (Note: I understand *why* multiple values are showing up--because the table referenced holds many-to-one (group-to-user) values. I just need it to only show unique group names if possible.
And some background on why I'm doing this (in case someone can think of a better way): The end goal here is to be able to employ a script that sets the 'Assigned to' on an Incident to the current user if its state is changed to Active and that field is empty.
  • Presently this script does not (cannot) work because
    • If 'Assigned to' is not empty, then 'Assignment group' must not be empty (I don't want to change this), and
    • The 'Assigned to' field is dependent on the 'Assignment group' field (i.e., the individual must be a member of the group selected).
So I did some research and found someone recommendations to create a 'Default Group' variable in the sys_user table, which I was working on testing, in order to be able to set up some additional script logic that will change/set the 'Assignment group' to the current user's default group where applicable (if current user is not a member of the current assignment group or if the assignment group is empty).
PS - This is my first post in the community. I've only been administering SN for my company since Sept. last year. Thank you all in advance for your help here.
randrews
after you click the magnifying glass to show that list view you screen shot <as an admin> right click on the list view header and select configure list layout
now move the columns you want onto that list layout and it should work fine.
