10-28-2020 01:39 AM
I have a requirement where i need to give specified time to user to review the form. when user clicks on alert button then my ui page should refresh. So that i can get all default values that was there on that ui page and my timer can restart .
I am not getting any code to refresh ui page so that my ui page timer restarts with default values.
Pls help.
Nikita
Request Management
Service Catalog
11-02-2020 12:15 AM
Hi Nikita,
I have created a similar case and I could achieve it. Here is what I have done.
UI action
function openPage(){
var dialog = new GlideDialogWindow('Test UI');
dialog.setTitle(getMessage('Testing 123'));
dialog.setPreference('label', 'Can you please choose an option?'); // This is the input for UI page, which would be default
dialog.render();
UI page
HTML
<g:ui_form>
<!-- Get values from dialog preferences passed in -->
<g2:evaluate var="jvar_label" expression="RP.getWindowProperties().get('label')" />
<g2:evaluate var="jvar_optionName" jelly="true" object="true" >
var options =RP.getWindowProperties().get('optionName');
options = options.split(",");
var choiceArray = [];
//<![CDATA[
for(var i = 0; i<options.length; i++){
choiceArray.push(options[i]);
choiceArray;
</g2:evaluate>
<input id="label_id" type="HIDDEN" value="$[jvar_label]"/>
<!-- Set up form fields and labels -->
<table width="100%">
<tr>
<td>
<g:ui_choice_input_field name="TestChoice" id="chooseOption" label="$[jvar_label]" mandatory="true">
<option value="">${gs.getMessage('-- None --')}</option>
<option value="other">Other</option>
</g:ui_choice_input_field>
</td>
</tr>
<tr>
<td colspan="2">
</td>
</tr>
<tr id="dialog_buttons">
<td colspan="2" align="right">
<g:dialog_button_ok ok="return getChoices()" ok_type="button" />
</td>
</tr>
</table>
</g:ui_form>
<button onclick="reincarnate()">Cancel</button>
</j:jelly>
Client Script
function reincarnate(){
var labelValue = document.getElementById("label_id").value;
GlideDialogWindow.get().destroy();
setTimeout(function(){ openPage(labelValue);}, 1000);
function openPage(value){
dialog.setPreference('label', value);
dialog.render();
In above example, I could destroy the GlideModal and recreate it.
In your case, You could create hidden input fields and store the values of parameters inside those hidden inputs.
Below are the inputs I see you are receiving in UI page
<j:set var="jvar_email" value="${JS:RP.getWindowProperties().get('email_ids')}" />
<j:set var="jvar_ccemail" value="${JS:RP.getWindowProperties().get('ccemail_ids')}" />
<j:set var="jvar_bccemail" value="${JS:RP.getWindowProperties().get('bccemail_ids')}" />
<j:set var="jvar_blacklist" value="${JS:RP.getWindowProperties().get('bclist_ids')}" />
<j:set var="jvar_sys_id" value="${JS:RP.getWindowProperties().get('sys_id')}" />
<j:set var="jvar_subject" value="${JS:RP.getWindowProperties().get('subject')}" />
Further on cancel, you can reopen the UI page by passing setpreferences from hidden fields.
Note : You need to use setTimeout and get value of hidden fields into variable before detroying the GlideModal.
11-01-2020 11:58 PM
Hi Nikita,
You can reload the RITM form but once page loads it needs a trigger to invoke the UI page
So this is not possible
Let user invoke the UI page again by clicking the UI action
10-28-2020 07:23 AM
You can try something like this
HTML:
<div id="result1">
initial page
</div>
<input type="button" name="refresh1" id="refresh1" onclick="refresh()">
Client Script:
function refresh(){
var res = document.getElementById('result1');
res.innerHTML = '';
var ga = new GlideAjax("<anyscriptinclude>");
ga.addParam("sysparm_name", "refreshmydata");
ga.getXML('mydata');
function mydata(response){
res.innerHTML = answer;
Script Include
function refreshmydata(){
var m = "<html><b>my new data</b></html>";
return m;
11-02-2020 12:15 AM
Hi Nikita,
UI action
dialog.render();
UI page
HTML
<g:ui_form>
//<![CDATA[
choiceArray;
</g2:evaluate>
<tr>
<td>
</td>
</tr>
<tr>
<td colspan="2">
</td>
</tr>
</td>
</tr>
</table>
</g:ui_form>
</j:jelly>
Client Script
dialog.render();
11-02-2020 04:06 AM
Hi Rahul,
Thanks a lot.
09-01-2022 12:08 AM
Hi Nikita, I have a similar requirement like you that I want to show some details in popup. I have tried with variable of type UI Page to render some HTML content but it's not working. Can you please help me with how are you displaying this popup and the information in it.
Thanks in advance
