Regular expression to include square braces
Srvs
Hi Team,
i need to split the below sentence using regex, Please help me out in 2nd line of the code.
i want to include the symbols [,],| as delimiters. please suggest me.
var data = "test comments [link title|http://example.com]"
var items = data.split(/[,|;]/);
var numSel = items.length;
 for (var i = 0; i < numSel; i++)
 gs.print(items[0])
 gs.print(items[1])
 gs.print(items[2])
output needed is:
test comments
link title
regards,
Srvs.
Bhavya11
Mega Patron
hi @Srvs
from your code Assuming urlify function is defined elsewhere
Please try like below
var finComment = 'test [Click Here|http://example.com]';
var htmlComment = finComment;
var sysIdList = htmlComment.match(/^(.*?)\s*\[(.*?)\|(.*?)\]$/);
if (sysIdList) {
    var part1 = sysIdList[1];
    var part2 = sysIdList[2];
    var part3 = sysIdList[3];
    var htmlOutput = part1 + '[code]<a href="' + part3 + '" target="_blank">' + part2 + '</a>[/code]';
    gs.print(htmlOutput);
    gs.print("No match found");
i am getting output as :
test[code]<a href="http://example.com" target="_blank">Click Here</a>[/code]
If my response proves useful, please indicate its helpfulness by selecting "Accept as Solution" and " Helpful."
BK
Hi @Bhavya11
its returning exactly in background script,
im trying to execute the  script in flow designer, which will take the input from jira and process for servicenow comments.
            var finComment = payloadObj.comment;
            var htmlComment = urlify(finComment);
            if (sysIdList)
            return part1 + '[code]<a href="' + part3 + '" target="_blank">' + part2 + '</a>[/code]';
        else {
            //gs.print("No match found");
input: testing123 [link title|http://example.com]
output getting into comments: testing123http://example.com][/code" target="_blank">link title
expected: testing123http://example.com][/code" target="_blank">link title</a>[/code]
i guess after url we have closing square braket ] is causing the issue. please suggest.
Hi @Bhavya11
i removed the $ symbol from  var sysIdList = htmlComment.match(/^(.*?)\s*\[(.*?)\|(.*?)\]$/);
now its working perfect.,
thanks a lot for your help 🙂
