Request item table not visible in flow designer
Akhil Vinay Ma1
I'm unable to see "sc_req_item" table in flow designer.
If it's on your personal dev, you go to developer.servicenow.com and login. Then through manage instance->actions->activate plugin. There in the list you should have something like "flow for service catalog" or similar.
//Göran
15 REPLIES 15
I have activated the plugin but in trigger condition which table i need to give to trigger the workflow and also in Flow field i'm unable to see the activated flows ?
Have you selected 'Service Catalog' as the trigger in the flow itself?
This worked for me
Hi ,
just wanted to understand we i am new to flow designer, does this mean in Kingston we cant use the flow designer to replace all service catalog workflows with flow designer ?
Goran WitchDoc
Yes, that is true. In Kingston release you don't have the functionality to use flows for Service Catalog.
//Göran
ok thanks
