Request state is not updating via update record in flow designer
04-09-2024 09:18 PM
Hi Community,
Trying to update request state via update record in flow designer but it is not updating request.
Other fields are setting but not request state when it is approved.
When rejected working fine but on approved facing this issue.
04-09-2024 10:31 PM
Using below cancel condition in ask for approval
04-09-2024 10:33 PM
Thank you for sharing the snippets!
Can you share expanded screenshots of Step : 10 - Update Request Record & Step : 23 - Update Request Record?
Please mark this as helpful and accept it as a solution if this resolves your query.
Sujatha V.M.
04-09-2024 10:40 PM
please find screenshot of step 10 and 23
04-09-2024 10:58 PM
Thanks for it! What happens if you remove the "Request State" field step in Line 23.
Just to check if BR is triggering based on RITM state change.
Sujatha V.M.
04-09-2024 11:19 PM
Removed the request state at 23 still it is not updating REQ
