RITM Catalog Item Change through flow designer
08-11-2025 05:01 AM
Currently, for certain catalog items where Flow Designer has been implemented, changing the item in an existing request successfully updates the item. However, the corresponding approvers are not added, and the details are not updated in the RITM.
08-12-2025 10:12 AM
Hello @Bella1418,
As per your requirement, you want the request to be updated with new variables and approvals when a user updates the catalog item — is that correct?
If so, please note that it's not possible to directly update the catalog item within an existing request. The best practice in ServiceNow is to cancel or close the current request and submit a new one with the correct catalog item.
Additionally, it's not possible to update the variables directly based on the updated catalog item. A new request must be submitted with the appropriate details.
Hope this helps!
If this solution resolves your issue, please mark it as the accepted solution and close the thread.
Thank you!
09-01-2025 03:33 AM
@Shashank_JainCurrently, in our system, the Workflow Editor is configured such that when an item is changed within a request, new variables are automatically added to the request details. Once these variables are filled in, the approval step is triggered as expected.
