Script help - How to get the value for variable field from the 'current' record
harinalamalapu
Giga Expert
How to get the value of a field on a current record using the 'current' keyword if the field name is a variable? Ex: current.u_description returns the description of the current record, say from a Change Request. but what if 'u_description' is a variable?
var result = current.u_description / This produced the result as "Sample Change Request"
Versus
  var fieldName = u_description;
  var value = current.fieldName     //tried this approach #1 - This produced the result as 'undefined'
  var value = current+'.'+fieldName   //tried this approach #2 - This produced the result as '[object GlideRecord].u_description'
I will have to use the above piece of code from a business rule on change request, so current refers to the current change record.
ghsrikanth
The system is searching for the column with the name fieldName, so it is not preferred to use parameter for the variable. If you want to use parameter its better to use getValue function.
var fieldName = 'u_description';
var value = current.getValue(fieldName); //this will work
Mark if it is helpful or correct
17 REPLIES 17
Have you tried current.variables.<variable_name> ?
Scriptable Service Catalog Variables - ServiceNow Wiki
Tadz
harinalamalapu
Giga Expert
Yes I have tried that but id didn't work. It produced a result of 'undefined'. Looks like the current.variables.<variable_name> format is only used for Service Catalog variables.
Maybe you have to used GlideRecord in that.
Tadz
harinalamalapu
Giga Expert
Ok. Can you please elaborate on that with an example ?
Hari
ghsrikanth
