Script help - How to get the value for variable field from the 'current' record
harinalamalapu
Giga Expert
How to get the value of a field on a current record using the 'current' keyword if the field name is a variable? Ex: current.u_description returns the description of the current record, say from a Change Request. but what if 'u_description' is a variable?
var result = current.u_description / This produced the result as "Sample Change Request"
Versus
  var fieldName = u_description;
  var value = current.fieldName     //tried this approach #1 - This produced the result as 'undefined'
  var value = current+'.'+fieldName   //tried this approach #2 - This produced the result as '[object GlideRecord].u_description'
I will have to use the above piece of code from a business rule on change request, so current refers to the current change record.
ghsrikanth
The system is searching for the column with the name fieldName, so it is not preferred to use parameter for the variable. If you want to use parameter its better to use getValue function.
var fieldName = 'u_description';
var value = current.getValue(fieldName); //this will work
Mark if it is helpful or correct
17 REPLIES 17
Hi Hari
Is 'u_change_activity' reference field on your current table??
If answer is YES then you can use GlideElement as shown below.
var techRisk ='u_change_activity.u_technical_risk';
gs.log('Risk: '+current.getElement(techRisk ));
Abhinandan
harinalamalapu
Giga Expert
Great, it worked. Looks like I can use 'current.getElement(variableName)' for both reference fields and non reference fields. Since in my requirement, I will have both reference and non reference fields as variables, and the above piece worked for both.
Yes it will work for both.
