Script to find whole word within a string.
dfry123
Mega Expert
I'm looking for help on how I can find a whole word within a string using a before business rule. Basically here's my scenario:
If the word "test" is in the short description field the business rule needs to run. I am not able to get it to only find "test".. it will bring back "testing" and "dtesting" as an example.
The script I have is below.. any help would be appreciated!! I just have it looking for test and displaying the message for testing purposes..
var ste = current.short_description.toString("test");
  if(ste.indexOf("test") > -1){
      current.u_business_development = 'true';
      gs.addInfoMessage("test is there");
})(current, previous);
Hi Rahul,
what would the regex be if I wanted to pull the entire string that starts with a word?
So my string is:
Notification time : 2021-10-09 16:58:09.035
Message : DB instance restarted
Event ID : http://docs.aws.amazon.com/AmazonRDS/latest/UserGuide/USER_Events.html#RDS-EVENT-0006
And I want to find the last 4 characters in the line that starts with "Event ID".
So for this example, I want to return "0006" because that line starts with "Event ID"
is this possible with regex?
thanks!
I ended up figuring this out...but if anyone sees a better way certainly chime in.  I used 2 regex expressions to first get my line, then my last 4 digits.
var statusInput = "This is my string and it has several lines like in a body of an email.  Event ID - this also part of my string and it ends with 0006";
var textOne = statusInput;
var pattern = /Event ID(.*)/;
var txtParse = pattern.exec(textOne);
var pattern2 = /.{4}$/;
var txtParse2 = pattern2.exec(txtParse);
output from this:  txtParse2 = "0006"
saurav1
Kilo Expert
Hey Darrel,
Just take the entire string in an array.
1. var a=" Your String";
Split the array with blank spaces.
2. a.split(' ');
Check which position contains the word string.
3.for(int i=0;i<a.length();i++)
if(a[i]=="string")
return (a[i+1]);
}else
return 0;
