Script to put all knowledge base categories/subcategories in an array
lmundere
I would like to write a script that pushes IDs of a specific knowledge bases into an array, taking into consideration that we can have a category, subcategory, subsubcategory etc, anyone can give me leads? The idea is to make some field mandatory on the category dependinding on what knowledge base it is inherited from.
Cheers.
Okay, try something like this, and let me know if it works for you.
var categoryGR = new GlideRecord('kb_category');
categoryGR.addQuery('parent_id', 'a7e8a78bff0221009b20ffffffffff17');  // sys ID of knowledge base you want to list
categoryGR.query();
var arrayCategoryValues = [];
while(categoryGR.next()){
    arrayCategoryValues.push(categoryGR.getValue('label'));
    findSubcategory(categoryGR.getUniqueValue());
if (arrayCategoryValues.length > 0){
    for (var i=0; i< arrayCategoryValues.length; i++){
        gs.info('Category label: ' + arrayCategoryValues[i]);
else{
    gs.info('No data found');
function findSubcategory(categoryID){
    var subCategoryGR = new GlideRecord('kb_category');
    subCategoryGR.addQuery('parent_id', categoryID);
    subCategoryGR.query();
    if (subCategoryGR.hasNext()){
        while(subCategoryGR.next()){
            arrayCategoryValues.push(subCategoryGR.getValue('label'));
            findSubcategory(subCategoryGR.getUniqueValue());
Thank you for your kind words!
