ServiceNow Implementation Specialist - ITSM Study Materials
‎06-12-2018 04:45 AM
I just completed my ServiceNow Implementation Specialist Certification in ITSM, and just like others I found it really tough to find study materials for this exam both in Community and elsewhere.
So, I got some documents for preparation of the exam, which I have attached. I don't have access to Blog so thought that this would be a better way if someone can get helped by this documents.
Based on my experience, if you go across this materials the exam will be a cake walk (keeping in mind the Admin is already Completed). I was not having permission to attach more than 10 MB at a go. So, I am attaching the following in the post:-
- CSM-ITSM Blue Print
- Incident Management
- Problem Management
- Knowledge Management
- Change Management
- ITSM Guided Set Up
There will be 1 more document (Service Catalog) which I will attach in the 1st comment itself and that will all together cover the entire syllabus as has been mentioned in the Blue Print.
Hope This Helps You All who are preparing for the Certification...!!
All The Best..!!
- 48,905 Views
‎08-29-2021 05:04 AM
Hi Angshuman,
This was very helpful, thank you for sharing documents. please share the service catalog document.
‎06-29-2018 09:13 AM
Hi Angshuman,
Could you please upload the file(10 mb) in Google drive and share us the link for it.
Thanks in Advance
‎01-13-2019 10:51 AM
You can just go to the link he provided and click on the ... to export it to a pdf.
‎07-11-2018 05:28 AM
‎07-11-2018 06:14 AM
Hi Pelo,
Good to hear that it Helped....!!
You can mark the Answer as Correct if it has helped you above..!!
And, Yes Congratulations..!!
Angshuman
