ServiceNow Implementation Specialist - ITSM Study Materials
Angshuman3
Mega Guru
I just completed my ServiceNow Implementation Specialist Certification in ITSM, and just like others I found it really tough to find study materials for this exam both in Community and elsewhere.
So, I got some documents for preparation of the exam, which I have attached. I don't have access to Blog so thought that this would be a better way if someone can get helped by this documents.
Based on my experience, if you go across this materials the exam will be a cake walk (keeping in mind the Admin is already Completed). I was not having permission to attach more than 10 MB at a go. So, I am attaching the following in the post:-
  • CSM-ITSM Blue Print
  • Incident Management
  • Problem Management
  • Knowledge Management
  • Change Management
  • ITSM Guided Set Up
There will be 1 more document (Service Catalog) which I will attach in the 1st comment itself and that will all together cover the entire syllabus as has been mentioned in the Blue Print.
Hope This Helps You All who are preparing for the Certification...!!
All The Best..!!
51 REPLIES 51
Hi Kemmy,
Did you give one more attempt after the exam? Can you shed light on the topics that were asked and why did u find the exam difficult?
Hi Kemmy,
Umadevi2
Many thanks for sharing.
Ankur Bawiskar
Any study material for Performance Analytics exam.
Please upload the same.
Hi Ankur,
You are referring to the PA materials for Micro Certification?
Angshuman
