ServiceNow Intune most recent discovery not correct
Ahmet1
We are using Service Graph Connector Microsoft Intune application.
We have configured it and its importing assets correctly however under the "Most Recent Discovery" field, the date and time is not correct (its not matching what its supposed to be transform mapped to).
The field Most Recent Discovery is mapped to "lastsyncdatetime" under IntegrationHub ETL , when I go into IntegrationHub ETL and do Test and rollback Integration results, I can see lastsyncdatetime correct however when the scheduled import runs the most recent discovery field is showing something different , it is showing a date and time nearly identical to the "Updated" field. not the last sync date time from Intune.
See below screenshots
Screenshot from IntegrationHub ETL Transform Map to CMDB configuration
Transform configuration
When viewing the CMDB Table , the most recent discovery is is showing different values
15 REPLIES 15
Hi, did you get a response from ServiceNow around this?
