Setting a default font and font size for html article body in Knowledge table
saranyavs
Hi team,
We have a requirement to set default KM HTML editor fonts as described below: Is there any method available to implement this feature.?
Main font - Arial 12
H1 font - Arial 18 bold
H2 font - Arial 14 bold
H3 font - Arial 12 bold
Saranya
Chaitanya ILCR
Giga Patron
Hi @saranyavs ,
try this go to the article body dictionary entry and add this in the default value
<style>
  p{
    font-family: arial, helvetica, sans-serif;
    font-size: 12pt;
  h1,h2,h3{
    font-weight: bold;
  h1{
    font-size: 18pt;
  }h2{
    font-size: 14pt;
  }h3{
    font-size: 12pt;
</style>
Chaitanya
Rafael Batistot
Hi @saranyavs
May you use an Article template to pre-configurate your fonts
  • You can create a KM Article Template with your preferred font and size applied to the body text.
  • When a user creates a new article using that template, the content will already have the formatting.
  • Limitation: this only applies to new articles created from the template. It won’t change the editor’s actual default font.
https://www.servicenow.com/docs/bundle/washingtondc-servicenow-platform/page/product/knowledge-manag...
If this response was helpful, please mark it as Helpful and, if applicable, as Correct.
This helps other users find accurate and useful information more easily
Chaitanya ILCR
Giga Patron
Hi @saranyavs ,
<style>
  p{
    font-size: 12pt;
  h1,h2,h3{
    font-weight: bold;
  h1{
    font-size: 18pt;
  }h2{
    font-size: 14pt;
  }h3{
    font-size: 12pt;
</style>
Chaitanya
