Setting default answers for Surveys
Alex Saager
Hi there,
I've been browsing the community for answers to setting default answers for survey question and yet to find an answer that works.
I have the below survey and want to set a default answer for the first 4 question:
I've gone into the assessment metrics and got it to display the default answer field but when clicking in the drop down box nothing is displayed:
What am I missing?
Many thanks,
Alex
9 REPLIES 9
Hi Alex,
Right click the Default Answer field & look for Calculated value table you will find Category Table field as a value in table.
Jaspal Singh
Hit Helpful or Correct on the impact of response.
Hey Jaspal,
Can you tell me what you referenced in the "dependent on field" to get your questions for surveys to appear in "default answer" field? I have changed it from category but I do not see any that would be right.
AgileTennis
Hey Alex,
Shawn McPherson
Hey guys, did anyone get this working?  All we want to do is set a default answer on a choice variable.  Seems pretty strait forward, but we don't want to break existing functionality.  Has anyone seen anything on HI regarding this topic?
Supreeth R2
Hello @Agile_Tennis1/ @Shawn McPherson,
I have a similar requirement as above and the Default answer seems to be drop down field showing values based on the dependent field selected which I really do not know why.
Did you guys find a way to achieve the above requirement of setting a default values to numeric scale data types or any other for Survey Management ? If yes, Please do let me know. Thank you!
Supreeth R
