Setting valid_to date of Knowledge article to 6 months after published date
neetika
Hi all,
I have written a business rule to set the valid_to date of Knowledge article to '6 months after published date'
This runs when n article is published, so an 'After' 'update' BR is used when 'State' changes to 'published'.
var gdt= current.published.getGlideObject();
  //gs.addInfoMessage("time:"+gdt);
  current.valid_to = gdt.addMonthsLocalTime(6);
})(current, previous);
Above is the script, but its not working. Something is missed.
Please correct me.
Hi neetika.gupta@infosys.com,
Were you able to find the solution?
I tried below AFTER BR for the same, with below condition and script.
CONDITION: current.operation("publish_knowledge") || current.operation("sysverb_update")
  // Add your code here
  var gr = current.published.getGlideObject();
  gs.addInfoMessage('The KB is drafted   on'           +   gr);
    current.valid_to = gr.addMonthsLocalTime(6);
  gs.addInfoMessage('Valid to Date is set to' + valid_to);
The validity date field shows empty does not get set to 6 months after published date. The BR does not work.
