SetValue of Reference field catalog client script
Rudi2
Hi Guys, just a question
I am a bit stuck and need to finish this script:
What I want to do is to return a name and use that name to set another reference field with the same name
I just need help with the set of the reference field
    if (newValue == '') {
var user_ref = g_form.getReference('user', loadInfo);
function loadInfo(user_ref) {
var gp = new GlideRecord('cmn_location');
      gp.addQuery('sys_id', user_ref.location);
        gp.query(function(gp){
  if(gp.next())   {
      var locname = gp.name;
        // This is working up until now
// NOW I NEED TO SET A VALUE ON A REFERENCE FIELD ON WHERE THE NAME IS THE SAME AS gp.name
Once this is done, what would be the best way to do this for another 2 reference fields?
Arindam Ghosh
Mega Guru
Hi Rudi,
For this scenario you need to use glide ajax, as you need to do DB operation through client script. So Create a Catalog Client Script and pass the User sys ID to Script Include where we do DB operation and again the location Sys ID sends back to Client script where we set the location. Please use the below script:
Catalog Client Script:
g_form.clearValue('location');
var user = g_form.getReference('user').sys_id;
var ajax = new GlideAjax('SetLocationUtil');
ajax.addParam('sysparm_name', 'setLocation');
ajax.addParam('sysparm_user', user);
ajax.getXML(function () {
      g_form.setValue('location', ajax.getAnswer());
Script Include:
Script include Name:   SetLocationUtil
and don't forget to check the Client callable checkbox.
Here is the Script for Script include
var SetLocationUtil = Class.create();
SetLocationUtil.prototype = Object.extendsObject(AbstractAjaxProcessor, {
setLocation: function(){
var user = this.getParameter('sysparm_user');
var gr = new GlideRecord("sys_user");
gr.addQuery('sys_id',user);
if (gr.next()) {
return gr.location.sys_id.toString();
else return '';
type: 'SetLocationUtil'
Arindam
Arindam Ghosh
Mega Guru
Hi Rudi,
Script Include:
if (gr.next()) {
else return '';
Arindam
