Should I Use Workflow, Process Flow, State Model or State Flow to customize Change Requests
Mudit
I want to Customize the Workflow for Change Requests. I want to add more states and define transitions for those. Also I want to create a workflow for the same.
ServiceNow offers an overwhelming number ways to do this.
Should I use State Models or State Flow or Process Flow or Workflows for this? I am confused.
Also some tutorial links would help.
Hi @Marion de Groot
at https://docs.servicenow.com/bundle/rome-it-service-management/page/product/change-management/task/t_... you will all instructions to add new states to the state model.
Regarding the Flow/Workflow Topic:
If you are a ServiceNow beginner, I wouldn't change anything. The reason is the complexity. Behind the scenes, there is an ongoing shift from Workflows to Flows. At Rome a Workflow is triggered when a Change Request has no assigned Change Model (https://docs.servicenow.com/bundle/rome-it-service-management/page/product/change-management/concept...). But if a Change Request has a Change Model then a Flow is triggered.
I think Change Request offer enough configuration possibilities to meet all requirements and therefore don't touch the Workflows/Flows.
Let me know if you have any further questions.
Kind regards
Maik
Marion de Groot
Hi Mudit,
You should use a Change Model for that: https://docs.servicenow.com/bundle/rome-it-service-management/page/product/change-management/concept/change-models.html
Thanks! I'll Check it out
Hi @Marion de Groot
Kind regards
Maik
Hi @Marion de Groot
In case you think I was able to answer your question, I would be happy if you mark the appropriate response as "correct" so that the question will appear as resolved for other users who may have a similar question in the future.
If not, please tell me what you are still missing!
Many thanks & kind regards
Maik
