showFieldMessage & ErrorBox msg nor working
Naveen87
Hey Guys,
Im trying put an error or info message under the field. But it's not reflecting.
g_form.showFieldMsg("start_date","Selected Date is in past, Select a valid date","info",true);
suggest me something here
Was that not happening before?
Actually, you know what...hmm...try clearing the field first THEN do your field message.
g_form.setValue('start_date', ''); // Setting the variable as empty
g_form.showFieldMsg('start_date', "Test 123", 'error');
17 REPLIES 17
Yea, you should be fine now to do more with it, info or error, etc.
I think it was basically because you were clearing the field AFTER the message which was probably happening about the same time and so it was causing a slight glitch there.
Please mark any other reply from others, as Helpful, if it was.
Take care!
Himanshu Dubey
Giga Guru
Hi Naveen,
You can achieve this by using UI policy no need to write a script
Please refer below link to know how to achieve by ui policy
https://community.servicenow.com/community?id=community_question&sys_id=55effeaddb58dbc01dcaf3231f96...
Mark ✅ Correct if my answer solves your issue and also mark 👍 Helpful if you find my response worthy.
Thanks & Regards
Himanshu Dubey
Hi Himashu,
Thank you for idea.
I had did it with UI policy only i beginning but due to changes in requirement. Approached script .
Script is fine and perfect.
Just trying to get an error msg under field.
Thank you
