SLA schedule including public holidays and weekends
psyherin
Hi all,
I am trying to configure SLA schedule to run on Weekdays 7-8 and Weekends & public holidays 9-5. Not sure if this configuration is correct or not. Appreciate if someone can advise on this below schedule.
Thank you.
13 REPLIES 13
Once you have added a new schedule entry you need to do a Repair SLA for breach time to be updated.
Repairing SLA doesnt fix the schedule entry. There are conflicting entries on the schedule so the SLA definition itself shows the time to breach which is taking Weekday schedule into consideration.
venky18
Hi @psyherin  is this requirement worked for you . if yes can you please reply here how u achieved i got same requirement
Sandra17
Hello @psyherin and @venky18,
have you solved the problem in the meantime? If so, could you please provide you solution? I have the same issue.
