Split function not working in script
04-12-2021 07:12 AM
Hello Team,
I tried putting logs and got an error message 'Split function not working'
"org.mozilla.javascript.EcmaError: Cannot find function split in object ".
Script:
answer = [];
SwissTriggerApproval();
function SwissTriggerApproval()
var affCIs = new GlideRecord('task_ci');
gs.log('Hello ' +affCIs);
affCIs.addQuery('task', current.sys_id);
affCIs.query();
while(affCIs.next())
//answer.push(affCIs.ci_item.u_task);
var list = current.u_watch_list_group;
gs.log('Hello1 ' +list);
var array = list.split(",");
for (var i=0; i < array.length; i++)
answer.push(array[i]);
gs.log('Hello2 ' +array[i]);
Error1:
org.mozilla.javascript.EcmaError: Cannot find function split in object .
Caused by error in sys_ui_action.f07eedb3cb200200d71cb9c0c24c9c3d.script at line 14
11: //answer.push(affCIs.ci_item.u_task);
12: var list = current.u_watch_list_group;
13: gs.log('Hello1 ' +list);
==> 14: var array = list.split(",");
15: for (var i=0; i < array.length; i++)
16: {
17: answer.push(array[i]);
Error 2:
Caused by error in sys_ui_action.f07eedb3cb200200d71cb9c0c24c9c3d.script at line 17
16: {
==> 17: answer.push(array[i]);
18: gs.log('Hello2 ' +array[i]);
19: }
20: }
16: {
19: }
20: }
PLease provide some inputs so that it can be resolved.
04-12-2021 08:05 AM
Hello Anirudh,
Thanks for the reply but no luck.
Could you please provide the exact code.
May be I am missing something.
04-12-2021 07:26 AM
Use and check once.
var array = list.toString().split(',');
Aman
04-12-2021 08:30 AM
Hello Aman,
No luck.
04-12-2021 07:40 AM
Hi
which type is the custom field "u_watch_list_group"?
I assume it is a reference field. If so you cannot split that field as basically there is only a sys_id stored in it.
Kind regards
Maik
If my answer replied your question please mark appropriate response as correct so that the question will appear as resolved for other users who may have a similar question in the future.
08-10-2023 11:22 AM
Please check this KB Article
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB1275119
Please mark my reply as Helpful and/or Accept Solution, if applicable. Thanks!
