State Model and UI actions issues
mbayefdieng
Giga Contributor
Hi everyone,   cameronrichard ctomasi
I am working on the state transition of my Normal Change model, and am facing this issue.
When I modify the script includes ChangeRequestStateHandler and ChangeRequestStateModel_normal, I see all the UI actions visible on the form, and the state field shows all transition states.
these UI actions are visible as form buttons and list button,
What did I do wrong?
Script of ChangeRequestStateHandler:
var ChangeRequestStateHandler = Class.create();
// All references to statehandler constants should be through this class ChangeRequestStateHandler
ChangeRequestStateHandler.DRAFT = ChangeRequestStateHandlerSNC.DRAFT;
ChangeRequestStateHandler.ASSESS = ChangeRequestStateHandlerSNC.ASSESS;
ChangeRequestStateHandler.BUILD = "build";
ChangeRequestStateHandler.SCHEDULED = ChangeRequestStateHandlerSNC.SCHEDULED;
ChangeRequestStateHandler.AUTHORIZE = ChangeRequestStateHandlerSNC.AUTHORIZE;
ChangeRequestStateHandler.IMPLEMENT = ChangeRequestStateHandlerSNC.IMPLEMENT;
ChangeRequestStateHandler.CLOSED = ChangeRequestStateHandlerSNC.CLOSED;
ChangeRequestStateHandler.CANCELED = ChangeRequestStateHandlerSNC.CANCELED;
ChangeRequestStateHandler.prototype = Object.extendsObject(ChangeRequestStateHandlerSNC, {
      initialize: function(changeRequestGr) {
ChangeRequestStateHandlerSNC.prototype.initialize.call(this, changeRequestGr);
              This.STATE_NAMES["-6"] = ChangeRequestStateHandler.BUILD;
      type: "ChangeRequestStateHandler"
Script of ChangeRequestStateModel_normal
STATE_NAMES: {
              "-5": "draft",
              "-4": "assess",
            "-6": "build",
              "-2": "scheduled",
              "-3": "authorize",
              "-1": "implement",
              "0": "review", \\ not a used state
              "3": "closed",
              "4": "canceled",
var ChangeRequestStateModel_normal = Class.create();
ChangeRequestStateModel_normal.prototype = Object.extendsObject(ChangeRequestStateModelSNC_normal, {
      draft: {
              nextState: [ "assess" ],
              assess: {
                      moving: function() {
                              return this.toAssess_moving();
                      canMove: function() {
                              return this.toAssess_canMove();
              canceled: {
                              return this.toCanceled_moving();
                              return this.toCanceled_canMove();
      assess: {
              nextState: [ "build" ],
              draft: {//if technical approver requests more information
                              return this.toDraft_moving();
                              return this.toDraft_canMove();
              build: {
                              return this.toBuild_moving();
                              if(this._gr.getValue("u_needs_build")=="Yes") return true;
                              return false;
              scheduled: {
                              return this.toScheduled_moving();
                              if(this._gr.getValue("u_needs_build")=="No") return true;
                              return false;
              canceled: {
      build: {
              nextState: [ "scheduled" ],
              scheduled: {
                              return this.toScheduled_canMove();
              canceled: {
      scheduled: {
              nextState: [ "authorize" ],
              authorize: {
                              return this.toAuthorize_moving();
                              return this.toAuthorize_canMove();
              canceled: {
      authorize: {
              nextState: [ "implement" ],
              scheduled: {//if on hold
              implement: {
                              return this.toImplement_moving();
                              return this.toImplement_canMove();
              closed: {//if rejected
                              return this.toClose_moving();
                              return this.toClose_canMove();
              canceled: {
      implement: {
              nextState: [ "closed" ],
              authorize: {//if put on hold
              closed: {
                              return this.toClosed_moving();
                              return this.toClosed_canMove();
              canceled: {
      closed: {},
      canceled: {},
      toBuild_moving: function() {
                                                        return true;
      toBuild_canMove: function() {
                                                        return true;
      type: "ChangeRequestStateModel_normal"
mbayefdieng
Giga Contributor
there is a typo in the code of ChangeRequestStateHandler:
because of this capital T in this.
16 REPLIES 16
amlanpal
Hi Mbaye,
So you have added one new state as Build which has choice value of -6. Could you please let us know when you want to let this state visible and from this state which states you allow to transit?
the state transition is defined in ChangeRequestStateModel_normal
State Transitions
Draft > Assess OR Canceled
Assess > Build OR Scheduled OR Draft OR Canceled
Build > Scheduled OR Canceled
Scheduled > Authorize OR Canceled
Authorize > Scheduled OR Implement OR Closed OR Canceled
Implement > Authorize OR Closed OR Canceled
Closed{}
Canceled{}
Hey,
Are you talking about this state transition??
if yes then this is a process flow.
Refer this -
Process Flow Formatter - ServiceNow Wiki
Process flow formatter
No, I provided a code (script) that controls the state changes.
the issue I have is to know why none of the conditions attached to the UI actions are true. hence them showing (visible) when they should not.
I need someone to review the script and validate it.
