Stop flow execution when running Business Rule
SS1510
We have a UI Action in incident form , to generate a request from incident. While field mapping catalog item flow overrides our BR values.  We have used async BR  and also used setworkflow(false). but still it is triggering the flow . we have successfully mapped the values on request form but in activity logs it is showing the override history. Is there any way to remove or hide the override values?
@SS1510
business rule should be after update on REQ
Condition: Parent Changes and Parent [IS NOT EMPTY]
// then update the REQ using setWorkflow(false)
OR
Make your flow wait for 10-20 seconds and then run it. you can use Wait for Duration
@SS1510
OR
@SS1510
