08-18-2022 02:31 AM
We have a String field in our staging and target table which has to copy the value from the sheet. when we are loading the data(transform map) it is changing the value which is being sent Example: if the value is like this 박명선 it is converting it something like l朱æ•�. When tried to updated the field manually it is getting copied correctly. Not sure what is causing the issue. We have the Chinese Translation in our instance
Thank you.
03-31-2023 02:23 AM
The file that im loading is having the issue, the source file provided has made some changes while sending the file and the issue is fixed now. thank you:)
08-18-2022 03:59 AM
I hope you are logging in as chinese user to confirm the value when you are checking on target table
08-18-2022 04:05 AM
Thank you
08-18-2022 04:56 AM
Please login with chinese user and verify the exact value.
Also check the file encoding when you are using Excel or CSV
03-31-2023 02:23 AM
07-19-2023 08:26 AM
What change did you have to make to file? Having same issue
