Target date is not auto populated in problem record
sukanya kotni
We want to update the target date field in the problem record automatically. It will update after 21 days of the opened date. This field should be read only.
We tried through one onload script and script include. It is working. But when we implement the notification for the problem record, the target date field is not coming because of the onload script. Then
We have created one business rule for the target date auto populate.
When condition - before/insert
Advanced -
  var cdt = current.getValue('opened_at');
  var ga = new GlideAjax('UserTimeZone');
  ga.addParam('sysparm_name', 'setQuarterlyValidDate');
 ga.addParam('sysparm_start', cdt);
 var answer1 = ga.getXML().getAnswer();
 current.u_rca_target = answer1.getDisplayValue();
})(current, previous);
script include:
var UserTimeZone = Class.create();
UserTimeZone.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    setQuarterlyValidDate: function() {
        var eDate = this.getParameter('sysparm_start');
        var dta = gs.getSession().getUser().getDateFormat();
        var gr = new GlideDateTime();
        gr.setDisplayValue(eDate, dta);
        var gdtLocal = new GlideDateTime();
        //gdtLocal.getLocalTime();
        var offset = gdtLocal.getTZOffset();
        gr.setNumericValue(gr.getNumericValue() + offset);
        gr.addDays(21);
        gr.getDisplayValue();
        return this._convertToGlideDate(gr, dta);
    _convertToGlideDate: function(gdt, fdta) {
        var gd = new GlideDate();
        gd.setValue(gdt.getValue());
        var ft = fdta.split(" ")[0];
        var d = gd.getByFormat(ft);
        d = d + ' 23:59:59', fdta;
        return d;
        datefieldDiffCal: function() {
        //var currentDate = gs.now();
        var currentDate = new GlideDate();
        var timeZone = gs.getSession().getTimeZoneName();
        var start = new GlideScheduleDateTime(this.getParameter('date_1'));
        var end =  new GlideScheduleDateTime(currentDate);
        start.setTimeZone(timeZone);
        end.setTimeZone(timeZone);
        //gs.log('dates'+ start+end);
        //gs.log('dates1'+ dt.split(" "));
        return gs.dateDiff(start,end, true);
    type: 'DateTimeZone'
Please help me on this issue.
Thanks in advance
Sukanya. K
Harsh_Deep
Hello @sukanya kotni
You are calling script include in wrong manner.
Use below code-
var ans = new UserTimeZone().setQuarterlyValidDate(cdt);
var date = new GlideDate(ans);
 current.u_rca_target = date;
    setQuarterlyValidDate: function(eDate) {
        gr.addDays(21);
        return d;
Hi @Harsh_Deep ,
Thank you for the respose.
I have tried as you mentioned in the above. The target field was not populated.
Sukanya. K
