The below script is triggering incorrect Events for notification .. how can I fix it ?
Pooja Khatri
I have written a business rule which is triggering multiple events in the single script , for every of the email notifications for request , task it is triggering event : normal_change.approval.inserted ... in ideal scenario , for isRequest function it should trigger : request.approval.inserted event for isSCTask it should trigger event : sc_task.approval.inserted and so on , I am not pasting down the entire script , but there is some issue with the below part of the code which is everytime triggering : normal_change.approval.inserted for any of the function call .
How can I fix the below part ?
if (current.state.changes() && current.state == 'requested') {
    var event = "";
    if (isRequest)
        event = "request.approval.inserted";
    else if (isSCTask)
        event = "sc_task.approval.inserted";
    else if (isStdChange)
        event = "std_change_proposal.approval.inserted";
    else if(isEmergencychange)
        event = 'approval.inserted';
    else if (isnormalchange)
        event = "normal_change.approval.inserted";
    else if (!(current.source_table == 'change_request' || current.sysapproval.sys_class_name == 'change_request'))
        event = "approval.inserted";
    if (event != "") {
        gs.eventQueue(event, current, gs.getUserID(), gs.getUserName());
        updateTask(current, current.approver.getDisplayValue() + " requested to approve task");
You can change the script shared by me.
Thanks and Regards,
Saurabh Gupta
