To call a script include using a flow
suuriyas
HI Community,
I have a requirement, i have created one script include what it does is it will create a sla record in sandbox instances (integration) when it is called. i have tested the script include in background script it works fine no issue.
Now i need to call that script include from flow have been trying many ways but i'm not able to achieve it.
so when the request is raised from a catalog item then in sandbox instances sla record need to be created and with the catalog variables like name type target these will get populate in sla record form and record is created.
what is the issue im facing is im not able to get the sysid of the ritm and pass it
Flow;
trigger condition service catalog
then created one custom action in that script step i have added like this
var reqSysId = inputs.requestSysId;
gs.info('debug request sysid' + reqSysId );
if(!reqSysId){
    gs.error('debug error: flow didnot recieve request sysid');
var ritm = new GlideRecord('sc_req_item');
//ritm.addQuery('request', requestSysId);
//ritm.query();
if(!ritm.get(reqSysId)){
    gs.error('debug no ritm found' + reqSysId );
//while(ritm.next())
try{
    gs.info ('debug caling si for' + ritm.number);
    var util = new SLAIntegrationUtil();
        util.createSLADefinitions(ritm);
        gs.info('debug si completed for' + ritm.number);
    } catch(ex){
        gs.error(ex);
})(inputs, outputs);
and input as
But in log it is showing as undefined and record is not getting created.
Please help me how to fix it
Thanks in advance
12 REPLIES 12
Ankur Bawiskar
@suuriyas
are you passing the RITM SysId properly to that custom flow action?
ensure everything is in lowercase in input variable i.e. Label and Name here -> Give it as requestsysId
then update script as this
var reqSysId = inputs.requestsysId;
@Ankur Bawiskar ,
Thanks for the response
Yes i have checked it is correct only but still im getting undefined
var reqSysId = inputs.requestsysid;
//var reqSysId = '2f19ddfdeb59be10b2bff25e1bd0cd89';
if(!reqSysId){
//ritm.query();
try{
    } catch(ex){
        gs.error(ex);
if i hardcoded the sysid then it is working fine sla record is getting created seems issue is with the first line alone not sure how to get the sysid
@suuriyas
type should be String
@Ankur Bawiskar ,
Tried that too but still it did not work
in logs im not getting the sysid of ritm it is still showing as undefined
