To check checkboxes based on field values
Poorva Bhawsar
Hi Community,
When user selects some variables values as approved from the dropdowns on catalog task, i want to check some checkboxes on the cmdb_ci form.
For e.g., if xyz is selected as approved from the dropdown list, then it should check xyz checkbox on the cmdb_ci form before closing the request.
it was not working because you changed the variable names for GlideRecord (you were using 'grCI' it should be 'gr1')
Try below:
else if (current.variables.oat_type == 'Database') {
    var server = [];
    var mrvsParsed = JSON.parse(current.variables.doat_server_details.toString());
    for (var x in mrvsParsed) {
        server.push(mrvsParsed[x].server_name.toString());
    //var server = current.variables.doat_server_details.server_name.toString();
    gs.log("OAT Type: Database, Server Name: " + server, "YourScriptName");
    workflow.info("OAT Type: Database, Server Name: " + server);
    var gr1 = new GlideRecord('cmdb_ci');
    //gr1.addQuery('name', server);
    gr1.addEncodedQuery('sys_idIN' + server.toString());
    gr1.query();
    while (gr1.next()) {
        if (current.variables.privilaged_account_onboarded_to_piam_confirmation_approval == 'accept') {
            //gr1.u_tpam == true;
            gr1.setValue('u_tpam', true);
        if (current.variables.database_onboarded_to_siem_confirmation_approval == 'accept') {
            //gr1.u_siem == true;
            gr1.setValue('u_siem', true);
        if (current.variables.cis_scan_nessus_scan_passed_confirmation_approval == 'accept') {
            //gr1.u_nessus == true;
            gr1.setValue('u_nessus', true);
        if (current.variables.ds_am_av_and_network_protect_with_ips_policy_is_set_to_prevent_or_ms_defender_installed == 'accept') {
            //gr1.u_av_am_ips == true;
            //gr1.u_xdr == true;
            gr1.setValue('u_av_am_ips', true);
            gr1.setValue('u_xdr', true);
            gr1.update();
            gs.log("Updated your_multiline_text_variable_set_table record for Database - Sys ID: " + gr1.sys_id, "YourScriptName");
            workflow.info("Updated your_multiline_text_variable_set_table record for Database - Sys ID: " + gr1.sys_id);
Please appreciate the efforts of community contributors by marking appropriate response as correct answer and helpful, this may help other community users to follow correct solution in future.
Anil Lande
34 REPLIES 34
@Poorva Bhawsar
Can you please share your latest script?
Also what logs you are getting?
Anil Lande
if (current.variables.oat_type == 'Server') {
    gs.info('Inside Server condition');
    var answer = [];
    var server_name = current.variables.server_name_s.toString();
    var arr = server_name.split(',');
    for (var i = 0; i < arr.length; ++i) {
        var gr = new GlideRecord('cmdb_ci');
        //gr.addQuery('name', server_name);
        //gr.addEncodedQuery('sys_idIN' + server_name.toString());
        gr.addQuery('sys_id', arr[i]);
        while (gr.next()) {
                gr.u_tpam == true;
                gr.u_siem == true;
                gr.u_nessus == true;
                gr.u_av_am_ips == true;
                gr.u_xdr == true;
        gs.log("OAT Type: Server, Server Name: " + server_name, "YourScriptName");
        workflow.info("OAT Type: Server, Server Name: " + server_name);
        //gr.update();
        answer.push(gr.toString());
        gs.log("Updated cmdb_ci record for Server - Sys ID: " + gr.sys_id, "YourScriptName");
        workflow.info("Updated cmdb_ci record for Server - Sys ID: " + gr.sys_id);
} else if (current.variables.oat_type == 'Database') {
    //var server = current.variables.server_name;
    var server = [];
    gr1.addEncodedQuery('sys_idIN' + server);
    gr1.query();
    if (gr1.next()) {
            gr1.u_tpam == true;
            gr1.u_siem == true;
            gr1.u_xdr == true;
        gr1.update();
@Poorva Bhawsar Use below script as it is:
    var answer = [];
        var grCI = new GlideRecord('cmdb_ci');
        grCI.addEncodedQuery('sys_idIN' + server_name.toString());
        grCI.query();
        while (grCI.next()) {
                grCI.u_tpam == true;
                grCI.u_siem == true;
                grCI.u_nessus == true;
                grCI.u_av_am_ips == true;
                grCI.u_xdr == true;
        grCI.update();
        answer.push(grCI.getUniqueValue());
        gs.log("Updated cmdb_ci record for Server - Sys ID: " + grCI.sys_id, "YourScriptName");
        workflow.info("Updated cmdb_ci record for Server - Sys ID: " + grCI.sys_id);
    var server = [];
    gr1.query();
            gr1.u_tpam == true;
            gr1.u_siem == true;
            gr1.u_xdr == true;
        gr1.update();
Anil Lande
I am using exactly same script but in the logs i am getting 4 logs which are changing continuously may be because of the loop.
If i will refresh logs then it will show another sys id at the top and the previous on is the next record.
Its not checking the checkboxes on the cmdb_ci table records.
Poorva Bhawsar
@Anil Lande  the script which you have shared is inserting 2 new records and ticking the checkboxes. For e.g., i have selected 2 cis from the list collector variable but its inserting 2 new records for one of the ci record. I just want to update in the current records for all the cis which i have selected in the list collector.
