To check checkboxes based on field values
Poorva Bhawsar
Hi Community,
When user selects some variables values as approved from the dropdowns on catalog task, i want to check some checkboxes on the cmdb_ci form.
For e.g., if xyz is selected as approved from the dropdown list, then it should check xyz checkbox on the cmdb_ci form before closing the request.
it was not working because you changed the variable names for GlideRecord (you were using 'grCI' it should be 'gr1')
Try below:
else if (current.variables.oat_type == 'Database') {
    var server = [];
    var mrvsParsed = JSON.parse(current.variables.doat_server_details.toString());
    for (var x in mrvsParsed) {
        server.push(mrvsParsed[x].server_name.toString());
    //var server = current.variables.doat_server_details.server_name.toString();
    gs.log("OAT Type: Database, Server Name: " + server, "YourScriptName");
    workflow.info("OAT Type: Database, Server Name: " + server);
    var gr1 = new GlideRecord('cmdb_ci');
    //gr1.addQuery('name', server);
    gr1.addEncodedQuery('sys_idIN' + server.toString());
    gr1.query();
    while (gr1.next()) {
        if (current.variables.privilaged_account_onboarded_to_piam_confirmation_approval == 'accept') {
            //gr1.u_tpam == true;
            gr1.setValue('u_tpam', true);
        if (current.variables.database_onboarded_to_siem_confirmation_approval == 'accept') {
            //gr1.u_siem == true;
            gr1.setValue('u_siem', true);
        if (current.variables.cis_scan_nessus_scan_passed_confirmation_approval == 'accept') {
            //gr1.u_nessus == true;
            gr1.setValue('u_nessus', true);
        if (current.variables.ds_am_av_and_network_protect_with_ips_policy_is_set_to_prevent_or_ms_defender_installed == 'accept') {
            //gr1.u_av_am_ips == true;
            //gr1.u_xdr == true;
            gr1.setValue('u_av_am_ips', true);
            gr1.setValue('u_xdr', true);
            gr1.update();
            gs.log("Updated your_multiline_text_variable_set_table record for Database - Sys ID: " + gr1.sys_id, "YourScriptName");
            workflow.info("Updated your_multiline_text_variable_set_table record for Database - Sys ID: " + gr1.sys_id);
Please appreciate the efforts of community contributors by marking appropriate response as correct answer and helpful, this may help other community users to follow correct solution in future.
Anil Lande
34 REPLIES 34
Hello @Poorva Bhawsar,
Can you please share the code, so we can verify if anything is going wrong.
Thanks!
Here we go...
if (current.variables.oat_type == 'Server') {
    gs.info('Inside Server condition');
    var answer = [];
    var server_name = current.variables.server_name_s.toString();
    var arr = server_name.split(',');
    for (var i = 0; i < arr.length; ++i) {
        var grCI = new GlideRecord('cmdb_ci');
        grCI.addEncodedQuery('sys_idIN' + server_name.toString());
        grCI.query();
        while (grCI.next()) {
            gs.log("Inside the loop");
            //grCI.getValue('u_tpam');
                //grCI.setValue('u_tpam', true);
                grCI.u_tpam == true;
                grCI.u_siem == true;
                grCI.u_nessus == true;
                grCI.u_av_am_ips == true;
                grCI.u_xdr == true;
        gs.log("OAT Type: Server, Server Name: " + server_name, "YourScriptName");
        workflow.info("OAT Type: Server, Server Name: " + server_name);
        grCI.update();
        //answer.push(grCI.getUniqueValue());
        gs.log("Updated cmdb_ci record for Server - Sys ID: " + grCI.sys_id, "YourScriptName");
        workflow.info("Updated cmdb_ci record for Server - Sys ID: " + grCI.sys_id);
} else if (current.variables.oat_type == 'Database') {
    var server = [];
    gr1.addEncodedQuery('sys_idIN' + server);
    gr1.query();
            gr1.u_tpam == true;
            gr1.u_siem == true;
            gr1.u_xdr == true;
        gr1.update();
Hi @Poorva Bhawsar ,
use below:
    var answer = [];
        grCI.query();
                grCI.u_xdr == true;
        grCI.update();
    var server = [];
    gr1.query();
            gr1.u_tpam == true;
            gr1.u_siem == true;
            gr1.u_xdr == true;
        gr1.update();
for "server" the grCi.update(); was outside while loop. So it was inserting new record.
Anil Lande
Hi Anil,
Thanks for the correction. Its working fine for the server. But its not working for database part.
Doat server details is a multi row variable set which contains 2 variables in it.
1. server name is a reference field.
2. DB names is a multi line text.
Whatever cis selected in server name field it should update those checkboxes accordingly.
Instead of assigning the values as true. I have used setvalue and it worked fine for the servers but not for the databases.
