To check checkboxes based on field values
Poorva Bhawsar
Hi Community,
When user selects some variables values as approved from the dropdowns on catalog task, i want to check some checkboxes on the cmdb_ci form.
For e.g., if xyz is selected as approved from the dropdown list, then it should check xyz checkbox on the cmdb_ci form before closing the request.
it was not working because you changed the variable names for GlideRecord (you were using 'grCI' it should be 'gr1')
Try below:
else if (current.variables.oat_type == 'Database') {
    var server = [];
    var mrvsParsed = JSON.parse(current.variables.doat_server_details.toString());
    for (var x in mrvsParsed) {
        server.push(mrvsParsed[x].server_name.toString());
    //var server = current.variables.doat_server_details.server_name.toString();
    gs.log("OAT Type: Database, Server Name: " + server, "YourScriptName");
    workflow.info("OAT Type: Database, Server Name: " + server);
    var gr1 = new GlideRecord('cmdb_ci');
    //gr1.addQuery('name', server);
    gr1.addEncodedQuery('sys_idIN' + server.toString());
    gr1.query();
    while (gr1.next()) {
        if (current.variables.privilaged_account_onboarded_to_piam_confirmation_approval == 'accept') {
            //gr1.u_tpam == true;
            gr1.setValue('u_tpam', true);
        if (current.variables.database_onboarded_to_siem_confirmation_approval == 'accept') {
            //gr1.u_siem == true;
            gr1.setValue('u_siem', true);
        if (current.variables.cis_scan_nessus_scan_passed_confirmation_approval == 'accept') {
            //gr1.u_nessus == true;
            gr1.setValue('u_nessus', true);
        if (current.variables.ds_am_av_and_network_protect_with_ips_policy_is_set_to_prevent_or_ms_defender_installed == 'accept') {
            //gr1.u_av_am_ips == true;
            //gr1.u_xdr == true;
            gr1.setValue('u_av_am_ips', true);
            gr1.setValue('u_xdr', true);
            gr1.update();
            gs.log("Updated your_multiline_text_variable_set_table record for Database - Sys ID: " + gr1.sys_id, "YourScriptName");
            workflow.info("Updated your_multiline_text_variable_set_table record for Database - Sys ID: " + gr1.sys_id);
Please appreciate the efforts of community contributors by marking appropriate response as correct answer and helpful, this may help other community users to follow correct solution in future.
Anil Lande
34 REPLIES 34
Are you getting logs for Server CIs?
Anil Lande
Server cis are working fine. But database one is not working.
Poorva Bhawsar
@Anil Lande can you please help me with the database part?
For database, i have a variable set which is a multi row variable set with 2 variables in it.
1. A reference field.
2. Multi line text field.
When user selects a ci from this reference field. It should update the checkboxes in cmdb_ci table.
Here is the else if part.
    var server = [];
    gr1.query();
            gr1.update();
Try below:
    var server = [];
    gr1.query();
            gr1.update();
Anil Lande
Poorva Bhawsar
Thank you for the quick solution.
