Transform map script
Kshitij Chakarv
I am creating a script to extract some specific value followed after a keyword.
answer = (function transformEntry(source) {
var GR = source.u_description.toString();
var index = GR.indexOf("Fault Offset:");
var offset = GR.substring(index, index + 9);
return "source.u_short_description + '' + offset";
})(source);
Intension is to get the value after 'fault offset:' from source description is set to a custom field.
I see no result using this script. Please advise on this.
2 ACCEPTED SOLUTIONS
anubhavritolia
Hi @Kshitij Chakarv
Which type of transform script are you writing?
Please mark this as correct answer and helpful if it resolved, or mark this helpful if this help you to reach towards solution.
Anubhav Ritolia
ServiceNow Rising Star 2023
Slava Savitsky
Try changing
to
return source.u_short_description + ' ' + offset;
9 REPLIES 9
Also keep in mind that indexOf() method is case-sensitive. For a case-insensitive lookup, use search() method instead.
anubhavritolia
Hi @Kshitij Chakarv
Please find updated transform map script below:
(function runTransformScript(source, map, log, target ) {
var desc = source.u_description.toString();
if(index!=-1)
var offset = GR.substring(13+index);
target.u_custom_field = source.u_short_description + ' ' + offset;
else
target.u_custom_field = source.u_short_description.toString() + ' ' + source.u_description.toString();
target.update();
})(source, map, log, target);
Anubhav Ritolia
anubhavritolia
Hi @Kshitij Chakarv
Please try below code:
if(index!=-1)
} else
return source.u_short_description.toString() + ' ' + source.u_description.toString();
return '';
Anubhav Ritolia
Thanks Anubhav, will try this. Please stand by 🙂
@Kshitij Chakarv
Did you got a change to try my solution?
Anubhav Ritolia
