Ui action script doesn´t work
Big Alex
I'm creating a UI action (button) in the ServiceNow sc_task table called "Create Story". The button should trigger a process to create a story record in the rm_story table and copy fields and attachments from the related Requested Item (RITM) to the new story. However, the button isn't working as expected because the script isn't even being called. I need guidance on how to implement the script so that clicking the button starts the flow or executes the necessary actions. We've already tried all approaches and configurations, and since the script isn't running, even looking at the log table is pointless.
The script runs on background scripts interface, so the script is ok. But why on earth he doesn´t run in the UI action is a mystery!
Thanks in advance!
11 REPLIES 11
Big Alex
Guys just an update on this one.
Our team have made some extra tests and could verify that the same UI action works well creating story from the incident table and also from the sc_req_item table. However for any reason that we don´t know it doesn´t create a story from the sc_task table.
So for now we could isolate the problem is in the sc_task table and will continue to troubleshoot.
We appreciate any inputs from you.
Thanks in advance
@Big Alex
did you try the script I shared?
