06-20-2016 08:20 PM
I have a iframe in the UI Page to bring the Incident list. How can i hide the nav header and breadcrumb in my iframe target list?
06-27-2016 07:19 AM
Teju,
I believe it should be jvar_ci_name instead of ci_name. Other than that everything looks good.
Abhinay
PS: Hit like, Helpful or Correct depending on the impact of the response
06-21-2016 01:40 AM
Thanks Abhu...I tried the above somewhere it is getting missed. So i used &sysparam_fixed_query in the iframe which leads to be to restrict the filters. One thing is it possible to restrict some columns in the list?
I want to remove the certain columns in the retrieved list it is possible?
06-25-2016 10:59 PM
Hi Abhinay,
I need your help on this pls. I made the UI page to display all the information as stated before BUT i need to display the cmdb_ci_name into the CI Name field but iam unable to do since it resides in cmdb_ci table. In my message i have "message2" which retrieves the cmdv_ci_name but cannot pass it into the html.
<html>
<head>
<g:include_script src="jquery_1_12_3.jsdbx"/>
<g:include_script src="jquery_dataTables_min.jsdbx"/>
<link rel="stylesheet" type="text/css" href="4a9d42b34f00220099ad34a18110c7e8.cssdbx" ></link>
<script>
$(document).ready(function() {
$('#dataGrid').DataTable();
</script>
<center><h2 style="color:black;">CMDB BaseLine Snapshot</h2></center>
</head>
<hr></hr>
<body>
<div id="section">
<div id="nav">
<td>
</td>
<center>
<br></br>
<div class="label_left" style="width:200px">
Select your Baseline:
</div>
<g:evaluate>
var bGr = new GlideRecord('cmdb_baseline');
bGr.addQuery('active', true);
bGr.query();
</g:evaluate>
<select name="baseline_name1" id="baseline_name" onchange="changeIncident()" value="${sys_basline_name}" >
<option value="${bGr.name}">--None--</option>
<j:while test="${bGr.next()}">
<option value="${bGr.name}">${bGr.name}</option>
</j:while>
</select>
</center>
<g:evaluate jelly="true">
<!-- var queryString = "sa_tablenameLIKEcmdb_ci^sa_sys_created_on>"+RP.getParameterValue('appName1'); -->
var queryString = "tablenameLIKEcmdb_ci^sys_created_on>"+RP.getParameterValue('appName1');
var sysGr = new GlideRecord('sys_audit');
<!-- var sysGr = new GlideRecord('u_baseline_cmdb'); -->
sysGr.addEncodedQuery(queryString);
sysGr.query();
sysGr;
</g:evaluate>
<hr></hr>
</div>
</div>
<table id="dataGrid" class="display" cellspacing="0" width="100%">
<thead>
<tr>
<th rowspan="2">CI Name</th>
<th colspan="2">Baseline Information</th>
<th colspan="3">Changes</th>
</tr>
<tr>
<th>Table Name</th>
<th>Field Name</th>
<th>Old Value</th>
<th>New Value</th>
<th>Reason</th>
</tr>
</thead>
<tfoot>
<tr>
<th>CI Name</th>
<th>Table Name</th>
<th>Field Name</th>
<th>Old Value</th>
<th>New Value</th>
<th>Reason</th>
</tr>
</tfoot>
<tbody>
<j:while test="${sysGr.next()}">
<g:evaluate var="sysparm_id">
var sysparm_id = RP.getParameterValue("baseline_name");
sysparm_id;
</g:evaluate>
<tr>
<td>${sysGr.documentkey}</td>
<td>${sysGr.tablename}</td>
<td>${sysGr.fieldname}</td>
<td>${sysGr.oldvalue}</td>
<td>${sysGr.newvalue}</td>
<td>${sysGr.reason}</td>
</tr>
</j:while>
</tbody>
</table>
</body>
<!-- </body> -->
</html>
</j:jelly>
Client Script:
function changeIncident()
var selValue = gel("baseline_name").value;
alert(selValue);
// Make a call to server side script-include using Glide Ajax
var ga = new GlideAjax('getBaselineDataIndex');
ga.addParam('sysparm_name','updateBaseLineIndex');
ga.addParam('sysparm_baseL',selValue);
ga.getXML(ResponseParse);
function ResponseParse(response){
var result = ga.requestObject.responseXML.getElementsByTagName("result");
var result1 = ga.requestObject.responseXML.getElementsByTagName("result1");
var message = result[0].getAttribute("answer");
var message2 = result1[0].getAttribute("answer1");
alert("message"+message);
alert("message2"+message2);
window.location.href="baselineTest-edited-direct.do?appName1="+message;
and also i can't set the baseline_name after loading the page it resets back to none.
06-26-2016 07:10 PM
Teju,
<tr>
<td>${sysGr.documentkey}</td> -- Here you want to display CI name right?
</tr>
Abhinay
06-26-2016 09:22 PM
Yes Abhinay, You are correct I want to display the CI Name as mentioned by you BUT CI Name will be in cmdb_ci or cmdv_baseline_entry for that particular baseline if we query but here we are querying the sys_audit table because we need old value new value and also reason for that baseline.
Can you help me to bring out the CI Name into that?
06-26-2016 09:56 PM
Teju,
Query on cmdb_ci table using the document key and get the name from there.
<tbody>
sysparm_id;
</g:evaluate>
<tr>
<g:evaluate var="ci_name">
var conf= new GlideRecord('cmdb_ci');
conf.get(${sysGr.documentkey});
conf.name;
</g:evaluate>
<td>${ci_name}</td>
</tr>
</j:while>
Abhinay
