UI Policy on variable Conditions not saving for Catalog Item
mattmm
I am creating a UI Policy to show or hide variables in my portal catalog item dependent on what is chosen in a select box variable.
When choosing the conditions "<variable name>" is "<actual variable name chosen>"
I save this to then setup my Catalog UI Policy Actions to show or hide the field , the condition then defaults back to " --none-- " (see second screenshot) as the variable name (i.e. "<variable name>" is --none-- ). Consequently my UI policy works as if it is --none-- and not what I chose before saving. Anytime I change, it defaults back to --none-- after saving.
NOTE: I've tried this with both "include None" and "Mandatroy" ticked and unticked with the same result. I also tried this with a multiple choice variable and same result. It works with a "Yes /No" variable though.
What am I doing wrong, or is this a bug?
Screenshots below-
Catalog Item Variable-
Catalog UI Policy-
UI Policy Action-
I've resolved this with help. I had a blank space at the end of my variable choice values! Removed the space and all is working as it should!
wowb8333
For anyone experiencing the same issue, use 'contains' instead of 'is'.
