Unable to load WSDL
Madhu5
I am trying to generate a Sample SOAP and I am getting the error "Unable to load WSDL".I am not using any MID server.Please find the attached screen for reference.find_real_file.png
Hi Hema,
Can you check correct username and password from another instance you are using in your soap message?
Generally authentication is required to get the sample soap message and wsdl
9 REPLIES 9
Hi Hema,
Chandra Prakash
Hi Hema,
Click on WSDL and check whether it is giving XML Payload or not.
reply for the same.
Chandra Prakash
Chandra Prakash
Hi Hema,
Invalid Authentication means you have to give correct username and password for Test.
Chandra Prakash
Ankur Bawiskar
Hi Hema,
Any update on this?
Can you mark my answer as correct, helpful if you were able to achieve the requirement. This helps in removing this question from unanswered list and helps users to learn from your thread. Thanks in advance.
SNOW Learner09
First and foremost thing we need to verify credentials that we are supplying in authentication. This will be the cause most cases.
