Unable to view the Executed Flow
Lucky1
Hello all,
I have created a flow in flow designer in my PDI. and now whe I open the flow and go to executions, it is giving up me this message.
Lucky1_0-1755075187717.png'
I also modified the Value in the above system property to "Full".
and also in Flow Reporting Settings
But Still I am not able to see the executions.
Can some one help me?
Lucky
ayla74108
Hi Lucky,
It sounds like the execution data isn’t showing even after adjusting the system property and Flow Reporting Settings. In some cases, this can happen if:
The "com.glide.hub.flow.reporting.enabled" property isn’t set to true (double-check that one).
The instance hasn’t collected any execution logs yet—try triggering the flow again after the changes.
Your user role doesn’t have permissions to view flow execution logs—check if you have the flow_designer and flow_operator roles.
The Flow Designer cache needs to be cleared—log out, clear cache, and try again.
If all of the above look fine, you might need to restart your PDI for the changes to take effect.
Let me know if it still doesn’t work and we can troubleshoot deeper.
Hi ayla,
In the Executions of flow designer, I am getting this:
I am not able to open the record, and view the details.
Lucky
Thanks for breaking this down. I’ll double-check the property and roles, then try triggering the flow again. If it still doesn’t show, I’ll restart the PDI and see if that helps.
