Uncaught ReferenceError: is not defined at HTMLButtonElement.onclick
sadiq
Hello guys I am trying to download the pdf format but unknowingly I get this error as Uncaught ReferenceError:
downloadIncident() is not defined at HTMLButtonElement.onclick
did anyone face this issue while working on UI pages?
HI @sadiq ,
I tried this code as is and it is working fine for me, no issue with code in my PDI. Please try this once in your PDI, if it is working in PDI, may be your organization instance is blocking some external scripts.
Anvesh
can you explain what have you done or which browser are you using?
@sadiq I Just created a UI Page and copied the HTML and Client Script as is, then created a Client callable Script Include and copied the code as is here too.
Opened the UI page and entered an Incident and clicked on download it downloaded a PDF.
Anvesh
Yes it worked for me too. it looks like there is some problem with the UI action I created. Thanks for acknowledging!
@sadiq Can you please accept my answer as solution and mark it helpful 👍✔️
Anvesh
