Update set preview problems
Poorva Bhawsar
Hi Community,
I have previewed an update set and got some update set preview problems/errors. When i am selecting 'accept remote update' and reloading it, its again showing those update set preview problems/errors with the same count and removing the option of 'accept remote update' from there. When i am selecting 'skip remote update' for those records, and reloading it, its again removing that 'skip remote update' and 'accept remote update' options from there.
Do anyone know why its happening. I have previewed or committed so many update sets till now. But i have never seen this issue ever.
Any solution to fix this?
Note: Its a scoped app and update set created by system itself when i created this custom app using app engine studio.
13 REPLIES 13
Then log a now support case @Poorva Bhawsar
Ok sure.
Ankur Bawiskar
@Poorva Bhawsar
try to delete that update set from retrieved set list.
Load again and preview
I did same already but no luck.
@Poorva Bhawsar
when you reload again does it show the accept and skip link again?
Did you try to clear instance cache using cache.do and then load again?
Seems the accept or skip is not happening on that error record and hence it shows the count again
Did you try with some other admin account and verify this?
