update sets were not retrieved because their batch base is not complete
Renu9
I am moving my update sets using update source functionality from dev to test.
I am having a parent update set with 3 child update sets , if I complete parent, the 3 child's were also got completed. In my test, when I click on retrieved completed update sets on update source I got parent along with 3 childs.
When I commit parent, all 3 child were also committed.
Next, as I got new requirement, I created child4 on same parent but by mistakenly I have completed child4 to complete without completing parent. I have completed parent after completing child3.
Whats the issue is , when I was  click on retrieved completed update sets on update source  I am getting below error.
Kindly suggest me how to resolve it or next action steps.
1 update sets were not retrieved because their batch base is not complete
But I see batch base as my parent name, where I open it, its showing as complete.
kartiksethi
Hi Renu,
Try deleting the update sets from the Retrieved Update Set table.
Remark: Delete the update set from the Retrieved Update Set table and NOT from the Local Update Set table.
After you delete the update set records from the Retrieved Update set table then try to pull the update sets again using Update Source.
Please mark my answer as correct if this solves your issues!
If it helped you in any way then please mark helpful!
Thanks and regards,
Kartik
kartiksethi
Hi Renu,
Thanks and regards,
Kartik
Hi Kartik,
I dont have anything in my retrieved update sets of my dev instance.
In my test instance, whatever I retrieved previously those I am having
Thanks, over retrieved update sets, I have searched with a sys_id and got the records and removed them, so later I tried retrieving the update sets and no issue found.
Hi @Renu
I am glad that I was able to help you. Thanks for marking my answer as correct!
Thanks and regards,
Kartik
