URL Redirection getURLForTask(current, 'rfc'));
imran rasheed
Can someone brief what this particular UI Action code does:
action.setRedirectURL(new StdChangeUtils().getURLForTask(current, 'rfc'));
This is being used to create standard change from an Incident. And it redirects to the below page.
I want this UI Action to re-direct to standard change catalog as highlighted rather than to "Standard change catalog->standard change" as it is right now.
Hi @imran rasheed & @Sai Kumar
Couple of things to note here:
1) OOB when a user click on Standard Change from Incident form, user are redirected to a page as below:
Service Catalog--> Standard Changes where Standard Change is a category and Service Catalog is a record defined under Catalog list menu.
Looks like there is a customization at your end where Standard change catalog is added to your instance. But for a solution what you are looking for you need to override the OOB Script include which is a protected one as per steps below:
1) Navigate to Script Include module and open the Script Include named as "StdChangeUtils". Link for the Script Include below:
https://instance.service-now.com/nav_to.do?uri=sys_script_include.do?sys_id=3f894542ffb00200b18affffffffff79
Replace "instance' with your instance name.
Now you need to define the same function below which is getting called in the UI action as mentioned below:
 getURLForTask: function(record, field) {
        if (!record || !field)
        var target = 'table:' + record.getTableName();
        target += ';sysid:' + record.getUniqueValue();
        target += ';field:' + field;
        var gu = new GlideURL('catalog_home.do');
        gu.set('v', '1');
        gu.set('sysparm_catalog', 'e0d08b13c3330100c8b837659bba8fb4'); // Replace the sys id with your Standard Change Catalog Sys id
        gu.set('sysparm_catalog_view', 'catalog_default');
        gu.set('sysparm_processing_hint', target);
		gu.set('sysparm_cartless', 'true');
        return gu.toString();
 Note: Instead o hard coding a sys id above, please create a System Property and then call the same in script above as a good practice.
For creating System Property, Navigate to "sys_properties.LIST" from Application navigator menu.
Create a property and then call it in above script using the syntax "gs.getProperty('Property Name');
So now when you click on Standard Change button from Incident you will be redirected to the page you want. This works for me in my PDI
Shloke
Shloke
shloke04
Hi @imran rasheed
Glad to help you here. If your query is resolved, can you please mark the answer as correct and close this thread for others.
Shloke
Shloke
Thanks a lot Shloke and Sai.!
shagun137
I want to add Create Standard Change from RITM in Workspace? How can the below code be modified to make functionality work in workspace?
