Use bearer token for REST Message authentication
Lucas Fernando
Hi.
I'm building a REST Message application to get data from a third-party API. However I'm stuck at the authentication setting.
To get the data I need, I need to use a bearer token, but this token only lasts for one hour. So I need to get the token (using POST) and, after it, make a GET request.
I can get the token, but I have no idea how I pass it as an authentication parameter to the POST request.
Has anyone faced this problem?
Thanks for the help.
Kamil Smusz
Hi Lucas,
You can create script include which will be using Rest Message to generate token - this will be function 1 then you can create second function and call there Rest Message to get data and pass token to this function from first function. In that scenario second function will trigger token generation each time when it will run. Example below
getToken: function() {
        try {
            var rm = new sn_ws.RESTMessageV2('xxx', "Token");
            var response = rm.execute();
            var responsebody = response.getBody();
            var httpStatus = response.getStatusCode();
            var a = JSON.parse(responsebody);
            var token = a.access_token;
            return token;
        } catch (ex) {
            var message = ex.getMessage();
            gs.error("xxx:Token:Error: " + message);
    getlist: function() {
        try {
            var date = new GlideDate();
            date.addMonthsUTC(-1);
            var rm = new sn_ws.RESTMessageV2('xxx', "GET list");
            rm.setStringParameter('date', date);
            rm.setStringParameter('token', this.getToken());
            return a;
        } catch (ex) {
            gs.error("xxx:getlist:Error: " + message);
In Rest Message you need to add token like below (name of the parameter may be different then authorization but it will be described in documentation from 3rd party)
26 REPLIES 26
Can you elaborate, i am not getting it or send screenshots for reference.
I doing like screenshot i shared and the code which is mention in this post.
hi @Divya2411 ,
Please share all screens related with Rest Message including main function where you have added HTTP methods
As @Kamil Smusz told you, share screenshots of what you have done so we can assist you.
Hi @Divya2411 ,
Looks like you don't understand how this should work. In your Token function you need to call Token Rest Message, not Post one, so you need 2 Rest Message calls one for Token and one for Get Data
