Use of (function executeRule(current, previous /*null when async*/)
imran rasheed
Can someone explain the purpose of below predefined function in business rules.
// Add your code here
})(current, previous);
Ankur Bawiskar
@imran rasheed
It's one of the template of writing your code within BR
The Script field is pre-populated with that template.
The function syntax is known in JavaScript as a self-invoking function or an Immediately Invoked Function Expression (IIFE). The function is immediately invoked after it is defined. ServiceNow manages the function and when it is invoked; developers do not explicitly call Business Rule Scripts.
Sharing the common syntax
1) Method 1
2) Method 2 - Define your function and use your code
restrictIncidents();
function restrictIncidents() {
// your code here
9 REPLIES 9
those are the parameters to the self-invoked function
the current and previous objects will help to fetch the previous and current value from the record on which BR runs
I found a question on a practice paper for the CAD exam.
Here is the Business Rule script template:
(function executeRule (current, previous */null when async*/){})(current,previous);
This type of JavaScript function is known as:
1. Constructor
2. Scoped
3. Anonymous
4. Self Invoking
I gave 4 as the answer but was advised that this was incorrect and that the answer is 2. Can anyone confirm either way please? @Ankur Bawiskar
From my understanding it's option 4.
I'd imagine that, if that's what you think then it must be true.
Thank you again Ankur.
JithinPadma
Can anyone please help me to understand the issue, how can I resolve it .am I missing any plugins?
