using a condition builder for a UI Policy to dot walk a reference field
patricklatella
I'm trying to use a UI Policy on a catalog item to make a field mandatory based on the reference variable to the sys_user table.   Is this possible?   Would a client script be better?
My variable is "user", and it's a reference field to the sys_user table.
I am then seeing the following in my condition builder:
but if I dot walk that to a field on the user record and set it to something that looks like it should work, it doesn't seem to apply correctly.
please try to have if statements inside curly braces {}, like
if(region == 'NA')
//Your code if condition code;
else
//You else condition code;
14 REPLIES 14
Hi Dan,
thanks for the reply.   I've just begun to see this odd behavior...so yes, I click here (see below), and then it brings up a thread where the I normally see the correct buttons.   But this one for example I don't.   This behavior is coinciding with another new odd behavior I'm seening...and that is where when I'm on the
This behavior is coinciding with another new odd behavior I'm seeing...and that is where when I'm on the home page and try to enter a new thread right there...the button does not work.   I then use the button to the right to start the thread.   It is on these threads that I cannot get to a "Correct Answer" button
Hi Patrick,
I'm seeing the same issue when creating a thread from the homepage.   However when the thread does get created after a few tries I am seeing the correct answer button.   Let me bring this to our dev folks.   They may reach out to you directly to further troubleshoot.
patricklatella
cool, thanks Dan!
Hi Patrick,
Our dev team thinks they have resolved this issue.   Can you please let me know if you continue to see it?   Before trying to post please be sure and refresh your browser.
patricklatella
Hi Dan,
still not working.   When I go to enter a new question in the main spot here
when the "ASK QUESTION" button appears, nothing happens when I click it.   So I have to click this button below to enter my question.
which is fine, except it is the questions entered this way that I still cannot see the "Correct Answer" buttons.
