Using For each loop in flow designer
shreya N shetty
In a particular flow in flow designer, there are cases where there is more than one child record, for example I have tested with record X which has 5 network cards. I think we have to add in the flow something like For Each loop before the send action for the child Cis.
While i am trying to achieve the above condition i observed that after chosing the "For each" conditon right after the lookup record step the data pill items are greyed out.
Can someone pls tell me  the exact issue??
Thanks in advance!!!
Ankur Bawiskar
You can iterate when you are using Lookup Records action
Please use Lookup Records action and then use the For Each and Select the 3-> Lookup Records
Ankur Bawiskar
