Validations on variable text field - Allow only Numbers and Special Characters
KARAN24
I want a validation  in my variable - only numbers and special characters should be allowed
Below code did not work. Can someone please help with the code for all the validations.
var pattern = /^[_A-z]*((-|\s)*[_A-z])*$/;
var name = g_form.getValue('number');
if (!pattern.test(number)){
g_form.addErrorMessage("Only Numbers and Characters are allowed");
Karan
Ankur Bawiskar
you can easily do this using Variable Validation RegEx
Then attach this to the variable you wish to
No need of client script
1) Regex -> ^(?=.*?[1-9])[0-9()-]+$
2) Link this with the variable
@KARAN
Hope you are doing good.
If so, please mark appropriate response as correct & helpful so that the question will appear as resolved for others who may have a similar question in the future.
Thanks!
@KARAN
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
Thanks!
Hi @Ankur Bawiskar,
Greetings !!!
The requirement that I have is to allow space as well as plus(+) character in addition to numbers and other special characters. Could you please guide me how can I modify following Regex to fulfil my requirement ?
Regex: ^(?=.*?[1-9])[0-9()-]+$
Would appreciate your help in this matter.
Thanks & Regards,
Gulzar Manuja
