‎06-28-2022 03:43 AM
var url = document.URL.parseQuery() is not working in Catalog Client Script.
I used the above line to set the value of the Services which is required to modified using a catalog item.
Thanks for the help in advance.
‎06-28-2022 03:45 AM
Hi Jatin,
Uncheck the isolate script checkbox. Then it will work fine
‎06-28-2022 05:43 AM
using DOM is not recommended.
There is an alternative to this as well.
‎06-30-2022 02:22 AM
What I can use instead of DOM?
Jatin
‎07-02-2022 11:24 PM
this should work
var url = top.location.href;
var comp = new URLSearchParams(url).get("sysparm_Comp");
