Variables not visible in sc_task
david_2508
I created an item with a properly workflow that works very well. The variables of the item encoded in the form appear correctly in the ritm and tasks.
In addition, I created a table and a related transform map in order to create ritm automatically after uploading Excel files. The variables also appear correctly in the ritm and the workflow also works well. However, the variables do not appear in the task or are integrated in the wrong task.
Can somebody help me about this issue, please ?
12 REPLIES 12
I am not sure ... if it getting hidden visibly , you need to search the scripts...
Hi Kalai.
I finally cleared the variables that were not included in the tasks and I have created new ones. Therefore, the variables appear well in tasks and my problem is solved.
I thank you once again for your help and wish you a merry christmas.
David
Wish you merry Christmas and a happy new year
