What does Attribute= "readonly_clickthrough=true" indicates in the Reference Qualifier.
Ram141
Hello All,
In the below link on the Reference Qualifier attribute is mentioned as "readonly_clickthrough=true" what does it indicates.
url
when we click on "Knowledge Base" Reference Qualifier icon it filter active KB's but in my Company instance it is showing all active false&true KB's.
Link where only active records are showing:
https://dev.service-now.com/nav_to.do?uri=%2Fkb_template_incident_kcs_article.do%3Fsys_id%3D-1%26sysparm_query%3Dsource%3D552c48888c033300964f4932b03eb092%5Eshort_description%3DAssessment%20:%20%20ATF%20Assessor%5Ekb_issue%3D%5Ekb_resolution%3Dtest
I''m not getting how they are filtering the active KB's, could someone please guide me on this.
Hyd
Ashutosh Munot1
HI,
readonly_clickthrough=true is to show the reference icon or info icon for that reference record.
Ashutosh
@MayurGavhane
Can you post a new question and tag me there as this is an old thread?
When you set this attribute as an override on a field does it disregard the parent attribute which is encode_utf8=false on the Task table.
Max
Ram141
Hello Ankur,Ashutosh,
Thanks for your response.
Could you please explain how do they set filter condition to show only active KB's.
Got it thanks for the response,they are using a business rule and they have added the business rule in "Default Dynamic Value" field
@hyd
Glad that it helped.
please close the thread by marking appropriate response correct/helpful.
